Activity Forums Apple Final Cut Pro Legacy Best and Cleanest Codec Workflow for Standard Def DVDs
  • Best and Cleanest Codec Workflow for Standard Def DVDs
    Posted by Joe Taylor on August 25, 2010 at 9:19 pm
    Have a question for those in the know. What might be best and cleanest codec Worklfow for standard definition DVDs made through Final Cut Pro and Compressor? I’m making demo-reels made with the Red ONE from 2K ProRess 422 files.
    Perviously my path would have been to Export the 5 min film to ProRess 422 HQ in Compressor. That ProRess 422 would be then down-rezzed to a 8.0 Mbps m2v file then imported into DVD Studio Pro for the final DVD output.
    My question is, is this an efficient way to get the best quality DVD with what I have to work with? Is exporting the original program to ProRess 422 then to the 8.0 Mbps m2v file necessary? (This was the workflow I was advised to take a year ago.)
    John Fishback replied 16 years ago 2 Members · 1 Reply
  • John Fishback
    August 25, 2010 at 9:58 pm
    Generally, it’s best to Export a self-contained Quicktime Using Current Settings from your timeline then use that in Compressor to encode the mv2 & ac3 files. A data rate of 8mbps is asking for trouble. You risk compatibility and playback issues. Many recommend (with programs less than 60 minutes) using a CBR of 6.5mbps and that assumes you’re using an ac3 rather than aiff audio file.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
