Activity › Forums › Apple Final Cut Pro Legacy › Best ambiant lighting for color correction
Posted by Jack Fox on January 28, 2007 at 11:31 pmI’m looking to paint my editing space and add some lighting. What kind of full spectrum lighting is best and what wall color is best. Thanks.
jmf
Jhaughey replied 19 years, 7 months ago 6 Members · 6 Replies -
Mark Raudonis
January 29, 2007 at 12:19 amQuick answer: Neutral grey with “Daylight” flourescent indirect lighting.
Long answer: Google “Best ambiant lighting for color correction” and you’ll get a ton of hits. Do your homework.
Mark
Michael Gissing
January 29, 2007 at 12:41 amActually you get this when you Google “Best ambiant lighting for color correction” you get-
Did you mean “Best ambient lighting for color correction”?
followed by a tip saying don’t use quotes.This link may actually be helpful
https://dvinfo.net/conf/showthread.php?t=80536 -
Jack Fox
January 29, 2007 at 1:34 amWhat is the best way to accomplish this, CIE D65 florescent, metal halide? Is the best position overhead fixtures, tract lighting? Can recommend a product?
jmf
Arnie Schlissel
January 29, 2007 at 3:44 amThe book “Color Correction for Digital Video” has a chapter on design & lighting for color correction & editing suites. I’d expect any similar book to have some brief mention of this as well.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Uli Plank
January 29, 2007 at 8:00 amYes, definitely get that book by Hullfish and Fowler (dmp, I think, check at http://www.dv.com). I’ve learned a lot more from it than only designing the suite.
Regards,
Uli
Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
Jhaughey
January 29, 2007 at 11:33 amWhen we were setting up our grading suite we had the guys from Silicon Color come round to check it out…
they said it was great, but one problem, the paint should be “18% grey”, so I had to paint the whole thing 18% grey…. its the same colour as Shake and Final Touchs’ backgrounds… makes sense when you see it.
don’t forget a daylight lamp behind your monitorJoe Haughey
https://www.pogofilms.com
