Activity Forums Adobe After Effects Best 3D model format for use in After Effects?
  • Best 3D model format for use in After Effects?
    Posted by Aaron Rosapepe on May 31, 2011 at 3:39 am
    Greetings,
    What is the best 3D model format for use in After Effects? I found a free ‘3Ds’ model and that seems to work ok. Is that the usual format or is there something better? Any I should avoid?
    Any recommendations on a site for purchasing 3D models to use in a project?
    Also, are there any detailed tutorials on working with 3D models in After Effects? I’ve googled but not much out there.
    Todd Kopriva replied 15 years, 2 months ago 4 Members · 6 Replies
  • Tudor “ted” jelescu
    May 31, 2011 at 4:57 am
    AE does not import 3d models directly- you can do it using a PSD 3d layer of a plugin like Zaxwerks Invigorator. Depending on what you use you can check out the specs on their respective websites.
    I have used 3DS models successfully with Zaxwerks Invigorator Pro.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Aaron Rosapepe
    May 31, 2011 at 7:28 am
    Thanks for the response! I was able to import the 3DS file into photoshop and than bring it into After Effects.
    When animating a camera move, I am noticing that preview times are very slow even with image quality taken to ‘quarter’ percent. Is this normal when working with 3D models in After Effects?
  • Anders Hattne
    May 31, 2011 at 11:03 am
    Like Tudor says, AE doesn’t support it directly. As far as I know Photoshop only takes OBJ files, Wavefront Oject I think that is.
    Not sure how textures are imported, but you can paint the model in 3d in PSD, save it and import the PSD in AE. On importing just remember to have live 3d selected, but I think that’s on by default!
    A
    http://www.ardillamedia.com
    May 31, 2011 at 2:26 pm
    My experience with PSD 3D layers was that AE is slow. Slower than with Zaxwerks- that is why I chose Invigorator for 3D in AE.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Aaron Rosapepe
    May 31, 2011 at 5:49 pm
    Excellent. Thanks for the tips!
  • Todd Kopriva
    June 12, 2011 at 6:35 am
    That’s not correct. See this page for the list of supported formats.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
