Activity Forums Apple Final Cut Pro Legacy Best 23.98 File for Hi Quality Full Screen Online Viewing ?
  • Best 23.98 File for Hi Quality Full Screen Online Viewing ?
    Posted by Howard Ferguson on June 1, 2009 at 11:00 am
    Hi !
    What are the best recommended settings for converting a 23.98 sequence to the highest possible quality (and speed) streaming video from a website ?
    Pixel Aspect set to NTSC – CCIR 601
    Field Dominance set to None.
    I’m in Final Cut Pro 5.1.4
    Thanks !
    Howard Ferguson
    Tom Brooks replied 17 years, 3 months ago 3 Members · 3 Replies
  • Rafael Amador
    June 1, 2009 at 11:27 am
    Hi Howard,
    What ever you do for the web needs to go in Square pixels.
    I guess you are working with NTSC DV Anamorphic.
    If you want your movie being display properly in the web, you need to keep the 16×9 aspect ratio.
    About the codec, the best option is h264. Set it with “Keyframes: Automatic”. Frame Reorder, Double Pass. data rate depending of the size you want output.
    rafael
    http://www.nagavideo.com
  • Howard Ferguson
    June 2, 2009 at 11:22 am
    Hi Rafael,
    Thanks very much for your response !
    In the Sequence Settings window in Final Cut:
    The Frame Size is 720 x 480
    Aspect Ratio is NTSC DV (3:2)
    Pixel Aspect Ratio: NTSC-CCIR 601/DV (…
    Anamorphic 16:9 is NOT checked
    Editing Timebase: 23.98
    Quicktime Video Settings
    Compressor: DV/DVCPRO- NTSC
    Quality: 100%
    Are these settings incorrect ?
    It is curious, because the image in the Canvas is actually 640 x 480.
    And it looks fine there.
    And when I Export, I have to Custom change the size to be 640 x 480,
    Otherwise, the result is a 720 x 480 Quicktime movie, which is warped out too wide . . .
    Also, in the Final Cut Browser window,
    all the video clips are listed as Frame Size 720 x 480.
    All of the video clips are listed with a Pixel Aspect NTSC-CCIR 601
    And all have Alpha: None/Ignore
    It seems maybe I’ve got some settings wrong ?
    Thanks for your help !
    Howard
  • Tom Brooks
    June 5, 2009 at 1:31 pm
    Your settings are fine in FCP. The pixels in your sequence are non-square as is normal for display on broadcast devices. But for display on computers, you need to compensate for the fact that pixels are square. You are correctly changing the image size to 640×480 on export.
    Your original question is such a huge topic. There are a ton of variables involved in answering it. I suggest you find a site similar to what you’re after and try to discover how it was done. Flash video seems to be dominant nowadays and H.264 is currently the hot codec.
