Activity › Forums › Adobe Premiere Pro › Benefits brought by dual core processors
Posted by Verdoni Philippe on February 16, 2006 at 12:58 pmBased on the fact that dual core processors are basically aimed at improving multi-task treatment, it is not clear to me which choice is the best for working with Premiere Pro; either a dual core or a single core having a higher frequency (for instance the AMD 64 X2 with two 2.0 GHz processors or the AMD 64 3800+ with one 2.4 GHz)
Derrick replied 20 years, 7 months ago 5 Members · 8 Replies -
Lyn Norstad
February 16, 2006 at 4:34 pmPhilippe –
We’ve found a dramatic increase in real time performance when switching from dual Xeons (HP xw8200) to dual dual-core Opterons (HP xw9300) utilizing the Matrox Axio system with HDV sources.
As always, the faster the better … but those differences are small compared to the enhancements from the AMD dual-core architecture.
Regards,
Lyn Norstad
Chicagoland, USA“Uff Da! It’s a dry cold.”
Blast1
February 16, 2006 at 11:35 pmMultiprocessors although they can multitask they are more suited to parallel processing, where instructions,etc are divided up between processors to increase through-put, the problem with MP is it needs to be programed to work, and alot of programs that run on both single processors and multi-processors don’t have all tasks in the program programed for MP,
some programs don’t show any increase in through-put because they aren’t programed for it, with programs that have alot of tasks suited to MP can show different percentages of through-put increase depending on whether the task is memory intensive or processor intensive, a rule of thumb is an average of 50% increase, so if you had two 3200+(2ghz) processors you might see a system that looks like a 4800+ processor or more. -
Verdoni Philippe
February 17, 2006 at 8:40 amThank you for these explainations, is Premiere (and particularly the Pro 2.0 issue) programmed for multi processors?
Lyn Norstad
February 17, 2006 at 3:02 pmYes. It is, in fact, what we’re using.
Regards,
Lyn Norstad
Paul King
February 18, 2006 at 11:14 amAsk Adobe, yes. But actually no. You wont see much benefit with Premiere alone. However Axio functions are fully multithreaded.
Also it’s not parallel processing, it’s multi-threading which is a bit different and gives better results for content creation.
Paul
Blast1
February 19, 2006 at 12:37 amAdobe used to have lists of what functions were enhanced for multi for Premiere 6.x, older versions of AFX, Il, and Photoshop, I don’t think they have bothered to update this info to bring it in-line with their new products.
Paul King
February 19, 2006 at 6:24 amNone of the filters are multithreaded in Premiere. However the media encoding is. I wish they would improve rendering speed, they seem to have been ignoring improving performance of Premiere when it comes to filters. If you have used Vegas (which I really hate) you will have noticed how fast and efficient it’s rendering is. I could never understand how one of the bottom end NLEs could have the best rendering engine – even better than Avid.
Paul
Derrick
February 20, 2006 at 6:56 pmLook at 3D programs, Blender3D which is free, has one of the smallest installs, and packes a mighty mighty punch, and even renders quick on my Celeron Laptop! Try that with a high end 3D app?
Who can ever excplain why the major players don’t try and improve there render engines, it would be awesome if they would though! (PLEASE ADOBE!)
– Derrick
