Activity Forums Zaxwerks bending text around object
  • bending text around object
    Posted by Brandon on November 30, 2005 at 12:11 am
    I am trying to bend text around a round object, but it proves difficult positioning each letter around the object and make it look right. Then I want to rotate around the object. Is there an easy way to do this. Thanks
    Brandon replied 20 years, 9 months ago 1 Member · 2 Replies
  • Brandon
    November 30, 2005 at 12:47 am
    Ok, I moved the text around the object and I am pleased, but when animate the rotation on my controller layer, it moves on the wrong axis. It spins instead of circling around the object. Is there a way to move the axis in the center so it circles around the object instead of spinning around on the front of the letters
  • Brandon
    November 30, 2005 at 1:54 am
    Ok…I figured everything out.
