Activity › Forums › Adobe After Effects › Bending objects/ videos in After Effects
Posted by Ryan Santos on January 29, 2007 at 2:53 amIn Premiere pro, there
Ryan Santos replied 19 years, 7 months ago 5 Members · 9 Replies -
Nate Vander plas
January 29, 2007 at 5:59 amWhat exactly do you mean by “bend?” I assume you want to do some sort of warping- if so you don’t need a plug-in. Just use the mesh warp effect. It allows you to move handles around on a grid and the image/video layer “bends” along the curved lines. You can also try the liquify effect for more precise warping.
Jason Jenkins
January 29, 2007 at 7:24 pmOr you could auto-orient the images to always face the camera.
Ryan Santos
January 30, 2007 at 12:10 amThanks guys. I also animated video clips to make them follow a really curvy motion path. But what it does is only follow the path while maintaining its “card-like” appearance. I wanted the video clips NOT to maintain its card-like appearance but rather to conform to every curve of the path, so that the video would bend on a sharp curve and be flat on a straight path. The final video is actually a person in the middle of video clips that fly around him. Is that possible with the available effects in AE or should I get a plugin? Thanks!
Steve Roberts
January 30, 2007 at 12:52 amSorry, but the only plugin that might be able to fake that is Forge Freeform, which hasn’t been updated in years, if I recall.
You have to bite the bullet: this is a job for a 3D app such as Max, Cinema4D, Lightwave, Maya or the like. Motion graphics require 3D apps more and more: they’re not just for robots any more! 🙂
Nate Vander plas
January 30, 2007 at 1:10 amDon’t give up yet! You may be able to use this technique:
Creating a 3D Filmstrip -
Nate Vander plas
January 30, 2007 at 1:57 amSorry, I guess that method does require a plugin! At least you don’t have to use a 3D app if this works.
