Activity › Forums › Maxon Cinema 4D › Bending an object in Cinema
  • Bending an object in Cinema
    Posted by Tracy Coats on April 3, 2009 at 9:16 pm
    I’m an industrial designer and I build a lot of objects from sheet metal and flat plastic panels. I’ve been trying to find out how to successfully bend a flat panel without having to make the object editable before adding the bend deformer. Is this possible?
    Brian Jones replied 17 years, 6 months ago 2 Members · 1 Reply
  • Brian Jones
    April 3, 2009 at 11:00 pm
    yes but give the ‘panel’ (I assume a Plane) enough Segments that it bends smoothly
