Activity › Forums › Adobe After Effects › Bending an object in 3D
Posted by Ben Mettler on February 18, 2010 at 6:32 pmI know this topic has been covered, but I’m just wondering if maybe with AECS4 there is a way to bend an object in 3D? I know there are plugins but I don’t have money to spend, unless there’s a free one. Any ideas?
Bartek Skorupa replied 16 years, 6 months ago 4 Members · 4 Replies -
Kevin Camp
February 18, 2010 at 6:59 pmcc cylinder is the only bundled effect that can bend a layer in 3d.
you can some control over how much a layer wraps around the cylinder by using the grow bounds effect prior to the cc cylinder effect.
adding the transform effect after the grow bounds will allow you to rotate or skew the layer before it wraps it onto a cylinder… using both of these you can get some interesting effects — animation of the cc cylinder rotation and position properties can then create a fairly believable falling/blowing sheet of paper, for example. but the basic effect will always be a flat layer wrapped around a cylinder — like a label on a glass, or something to that effect.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Michael Szalapski
February 18, 2010 at 7:01 pmHow do you want to bend it?
If you put your image in a comp that’s a lot larger than it is, then apply CC Cylinder to that comp you’ll get a bend from it.
Or, instead of the larger comp, apply Grow Bounds before you apply CC Cylider.– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Michael Szalapski
February 18, 2010 at 7:02 pm*sigh*
Curse my getting distracted by work in the middle of typing a post! You beat me to it, Mr. Camp! 🙂– The Great Szalam
Bartek Skorupa
February 18, 2010 at 7:05 pmNothing changed in this area comparing to CS3. After Effects remained 2.5D app.
CC Cylinder may help, but don’t expect miracles.(5 replies at the same time, mine is now looking a bit stupid 🙂
Bartek Skorupa
Warszawa, Poland
