Activity Forums Adobe Illustrator Bending a gradient
  • Bending a gradient
    Posted by David Cabestany on September 28, 2009 at 3:11 am
    Hello all,
    I’m trying to replicate an aluminum tube which has a somewhat related to a funnel shape. I created a nice gradient which mimics the texture and illumination of aluminum, but I haven’t been able to bend the light streaks at the bottom, I tried to create a gradient mesh and also blending several objects, but when there is so many color variations, both options get very tricky and yield poor results.
    Does anyone can think of a way of bending the gradient fill to follow a certain path or something like that?
    Here’s an image of what I’m trying to do, I think it’s pretty self explanatory:
    Best,
    D.
    David Cabestany replied 16 years, 11 months ago 2 Members · 2 Replies
  • Les Nemeth
    October 3, 2009 at 12:01 am
    Use blends. Eg, make 4+ lines as in the figure below. Color them appropriately, then blend:
    Blend 1
    You can also create fancy blends this way, eg a CD/DVD:
    CD-ROM
  • David Cabestany
    October 3, 2009 at 12:33 am
    Hi Les, thanks for your reply.
    Your example is very good, is so simple and practical that made me think: Why I didn’t think of that? Clear indicator of a good idea.
    Unfortunately I was in a hurry with such project so I ended up creating a gradient mesh that although took me a lot to create it came out nice, but I for sure will try your method next time.
    David.
