Activity › Forums › Adobe After Effects › Bend or crease a layer in AE
Posted by Mitch Hardison on August 10, 2011 at 4:11 amI can’t figure out how to do this effect. They bend the layer with the text on it and make it look like its unfolding. Anyone know how?
Mitch Hardison replied 15 years, 1 month ago 3 Members · 6 Replies -
Mitch Hardison
August 10, 2011 at 4:13 amare they using masks to divide the layer and rotating each one?
Darby Edelen
August 10, 2011 at 5:15 amWho are “they” and can you show us what they have done?
There are lots of different ways to make text bend in either 2 or 3 dimensions. The technique you use will depend on the results you’re after.
Darby Edelen
Tudor “ted” jelescu
August 10, 2011 at 10:36 amPosting an example (still or video) will help.
You are probably referring to a 3d distortion.
This can be achieved with Free Form.Here’s a tutorial that shows how Free Form can be used:
https://library.creativecow.net/jelescu_tudor/3D-from-2D-image_AE/1Tudor “Ted” Jelescu
Senior VFX Artist -
Mitch Hardison
August 10, 2011 at 2:15 pmI always forget to post the freakin link!!! sorry guys. I’m really not that stupid
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tudor “ted” jelescu
August 10, 2011 at 6:37 pmThis looks like a straight 3D AE animation.
Here’s a recipe:
Break down the text plate in as many layers as you need for the folding. Set anchor points on the fold line. Parent in the right order (outer pieces are parented to those close to the center and those to the center piece. Animate in reverse. Once the piece is unfolded cut to full title plate to avoid seeing lines in between the various parts. Use Motion Blur… i usually take that with coffee.Tudor “Ted” Jelescu
Senior VFX Artist
