Bend It cuts off shape
I am trying to use the BEND IT effect to bend a shape which I will use as a character’s arm. This works beautifully until the shape reaches the halfway mark (see fig 1) but after that, the shape hits a border area, and disappears. I have already checked that my arm layer is the same size as my composition, and even made it double the composition size. I have also applied the BEND IT effect directly to the layer, and tried applying it to an adjustment layer. I have applied the GROW BOUNDS effect (as suggested in another post) both above and below the BEND IT effect. Nothing has helped.
I tried setting the BEND IT start point to the center of the arm and using the “mirror” setting, but that throws off the animation, because the shoulder is no longer the central rotation point.
I also tried the Puppet Pin Tool, but don’t like how it distorts the shape, even though it’s only a slight distortion.
Any suggestions would be welcome.
11233_bendit.jpg.zip
Thanks.
