Activity Forums Maxon Cinema 4D bend issue
  • bend issue
    Posted by Mohsen Amini on December 17, 2018 at 5:19 pm
    hey guys. this is probably easy one for you. i got this stupid tree like objects. i want to animate it emerging from ground. so put the bend on the ground and trunk can bend 2 times nicely. but as we need to animate the group it also bends the platonic object. how can make a better grouping or make bend not affecting the other object? I think screen shot is clear but attached the scene anyway also. thanks guys ^^
    12958_issue.c4d.zip
    Mohsen Amini replied 7 years, 8 months ago 3 Members · 4 Replies
  • Brian Jones
    December 17, 2018 at 11:59 pm
    this is one way, clone the top onto the trunk (trunk needs to be editable) so the bend doesn’t affect it.
    12962_issue2.c4d.zip
  • Mohsen Amini
    December 18, 2018 at 1:04 am
    haha that was a nice creative way. thanks. but can u think of more stable way? there is gotta be a way to use any kinda objects without making them like this…
  • Emir Bojorquez
    December 18, 2018 at 1:11 pm
    Probably this could help you to start:
    12963_exampleconst.zip
    Good Luck
    Imagination is the best tool…
  • Mohsen Amini
    December 18, 2018 at 3:56 pm
    Oh thanks man. actually i found the solution. we should use restriction tag based on uv or points. then we can restrict bend deformer to affect areas we want
