Activity › Forums › Adobe Premiere Pro › “bend” Clips…?
“bend” Clips…?
Posted by Uwe Lansing on June 1, 2005 at 11:55 amHi,
is there any possibility to “bend” clips in order to put them in a filmstripe like this:
https://hometown.aol.de/Beispiel0/Unbenannt-1.pngTips for plugins also welcome…
Uwe Lansing replied 21 years, 3 months ago 2 Members · 6 Replies -
David J
June 1, 2005 at 1:33 pmI don’t know of a plug-in that would automate this effect. However, an approximation shouldn’t be too difficult to construct in Premiere.
The filmstrip could be a still image with transparent alpha-channel holes to allow underlying tracks to show through.
Individual clips playing in each window in the filmstrip could be scaled and rotated using Motion, possibly with the application of the Wave Warp effect to bend the picture to match better the bend of the filmstrip.
If you want to bend the filmstrip dynamically, then make the basic composite in a separate sequence and apply the warp effect to the whole sequence on the main timeline.
If you are using all stills, then similar work in PhotoShop to produce a composite image would probably be less fiddly than doing it all in Premiere.
Uwe Lansing
June 1, 2005 at 2:40 pm>>Individual clips playing in each window in the filmstrip could be scaled and rotated using Motion, possibly with the application of the Wave Warp effect to bend the picture to match better the bend of the filmstrip. << Exactly. This is want I want. Thank you for your answer. Is the "wave warp effect" include in APP 1.5 or a separate plugin? (my problem is to find the effect in my german version...)
David J
June 2, 2005 at 11:11 amWave Warp is a standard effect in the Distort category in the English version of Premiere Pro. Ich kenne die W
Uwe Lansing
June 2, 2005 at 11:39 amThank you David. I find the effect in the german version (Komplexe Wellen). But, the problem is: this (and other) effects changes the content of the clips, not the outlines (borders)…
There is another effect in APP (named in german “Eckpunkte verbiegen” > “bend corners” in english?). But you can
David J
June 2, 2005 at 4:52 pmYou might also try the Lens Distortion effect after applying Motion to shrink the clip. You can see more easily what it does if you use the setup screen rather than the Effects Control Window sliders.
Uwe Lansing
June 3, 2005 at 3:00 pm…after some trials with the Wave Warp Effect… now, it works very well => Danke!
kind regards
Uwe
