Activity Forums Adobe After Effects Bend a shape
  • Bend a shape
    Posted by Olivier Mercier on June 24, 2025 at 4:22 pm
    Hi guys and girls, I’m having issue with a simple task . Bending a layer from the center.
    I want a regular rectangle to change shape into this (see pic)
    CC bend it do not work
    Warping(s) does not work
    Any distorsion I tried did not worked
    Seems very simple but I can’t figure this out.
    Thanks guys !
    Olivier Mercier replied 1 year, 2 months ago 2 Members · 2 Replies
  • Paul Minnaar
    June 24, 2025 at 6:17 pm
    Hi Oliver,
    The key here, is to use a Shape Layer. Add your shape, then move the anchor point (pan behind) to the centre of the shape. Add a CC Bend It effect, move the ‘start’ of the effect to the centre of the shape. You can now animate the bend on the timeline.
    Regards
    Paul
  • Olivier Mercier
    June 24, 2025 at 7:04 pm
    Thanks you SOOOOooo Much. Sir !
