Activity › Forums › Apple Final Cut Pro Legacy › Benchmarking FCP 7 or Mac Pro
  • Benchmarking FCP 7 or Mac Pro
    Posted by Peter Tours on September 14, 2010 at 11:19 pm
    I am wondering if there is any way to determine if my puter is running up to snuff? FCP seems soooo boggy. It hates unrendered material with filters even in unlimited mode with the rez to medium. Format is DVCPRPO HD 720pn24 in a DVCPRO HD 59.94 timeline.
    Octo 2.93
    Raid Card
    4 x 640gb
    OSX 10.5.8
    FCP 7.0.2
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    Peter Tours replied 16 years ago 2 Members · 3 Replies
  • Shane Ross
    September 15, 2010 at 12:25 am
    I was able to edit that format with a far INFERIOR machine…a 2Ghz Powermac G5, with the footage stored on FW800 drives.
    Bogged down? Repair permissions with the Disk Utility…trash preferences. Perhaps get the FCS Maintenance Pack from https://www.digitalrebellion.com and use the tools to clean out your system.
    Shane
  • Peter Tours
    September 15, 2010 at 4:13 pm
    Yessir, I am a disciple of Larry Jordan so I have had that routine down long ago.
    Ran FCP Maintenance Tool as you suggested. It hasn’t found anything funny, but did display crash reports that say FCP overloaded probably from too many layers at the play head or too many filters in them. Not sure what to do from there – I do stack ’em deep and also rely on Boris Red in the timeline, which I expect to slow things down until rendered.
    But pretty much if I hit the space bar even before straight cuts, it’s possible – nay probable – I will get the “spinning beach ball of death” then audio then finally video and the whole process takes some time. However the play head may not actually move…and yes I used unlimited in dymanic modes.
    2 theories:
    1. I am indeed doing too much in the timeline
    2. My 4th Mac Raid Card is starting to wet the bed…
    3. Something to do with the grfx card? Radeon 4870HD
    Peter Tours
    Fort Lauderdale, FL
  • Peter Tours
    September 15, 2010 at 10:27 pm
    I guess this might explain it…..
    Peter Tours
    Fort Lauderdale, FL
