Activity Forums Adobe Audition Behringer X-32 not working w/AuditionCC
  • Behringer X-32 not working w/AuditionCC
    Posted by Bo Roberts on December 22, 2016 at 6:02 pm
    I am not able to record to Audition using the X32Producer USB output. Audition sees the output but will not record. I am trying to do a multitrack recording, using 4 of the 8 output channels. I have tried several options, any guidance on this is very much appreciated. Once I arm the channel of Audition the channel will revert back to “none” under the input option after about 10 seconds. I guess there must be some settings that need to be in certain order to do a recording. I spoke with someone from Behringer and he said it’s an Audition problem, not a board problem. Thanks!
    Bo Roberts replied 9 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
