Activity › Forums › Adobe After Effects › Beginner with After Effects
  • Beginner with After Effects
    Posted by Milton Wershow on October 8, 2009 at 6:54 am
    In diapers here and need an explanation what this means below.. Do not understand where I begin to drag composition into another. Can you help?
    https://library.creativecow.net/articles/james_colin/glass.php
    Once you are happy with how your planes of glass are going to animate on screen, drag our Glass Setup 1 comp into top layer of the Render-Comp. Now go to the Layer menu and add a new Adjustment Layer. Call this adjustment layer ADJUST-1. Put the ADJUST-1 layer BELOW the Glass Setup 1 layer. Set the Track Matte for the ADJUST-1 layer to Alpha. See, what this is doing is telling after effects to only apply the effects that at we will put on the ADJUST-1 layer, where the solids on the Glass Setup 1 layer are.
    Ramanji Raja replied 16 years, 11 months ago 3 Members · 2 Replies
  • Todd Kopriva
    October 8, 2009 at 3:00 pm
    Compositions are listed in the Project panel, along with footage items. You can drag a composition (composition A) from the Project panel into the Timeline panel for another composition (composition B); this adds (nests) composition A inside composition B. When a composition is nested inside another composition, it is also called a “precomposition”.
    See “About nesting and precomposing” for a full explanation. The last section on that page points to some beginner-level introductions/tutorials about nesting and precomposing.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Ramanji Raja
    October 10, 2009 at 3:00 pm
