Activity › Forums › Adobe Premiere Pro › *Beginner Question* Stutter Issue when exporting with PP2.0
  • *Beginner Question* Stutter Issue when exporting with PP2.0
    Posted by Ryan Carlson on November 2, 2006 at 9:44 pm
    Hello, I’m a beginner with Premiere Pro and I’m running into a stuttering issue when I export. (right now just exporting to a movie file)
    I captured my DV clips via firewire and when I play the clips on their own they look clean. Then I import into Premiere, edit the clip and then export. The exported file has a pretty consistent stutter. I turn off the Frame Blend but not sure what else I can do to eliminate the stutter.
    I would really appreciate help helpful advice for this beginner.
    Ryan Carlson replied 19 years, 11 months ago 2 Members · 2 Replies
  • Mike Velte
    November 3, 2006 at 12:20 pm
    Tell us a bit about your computer, its processor and drive configuration. Are you exporting to DV tape?
  • Ryan Carlson
    November 3, 2006 at 4:51 pm
    Hi Mike,
    In reading the archived posts last night I found my answer and it WORKED!!! it was just a matter of making sure exported frame rate matched the project frame rate.
    Thank you for responding.
