Activity Forums Adobe Premiere Pro Beginner, Q? How to export my timeline from Premiere Pro to Encore/Authoring the DVD menus
  • Beginner, Q? How to export my timeline from Premiere Pro to Encore/Authoring the DVD menus
    Posted by Emmanuel on October 12, 2006 at 7:02 am
    I just started reading Classroom in a book for PP2.0 and Encore. i think iam doing well.
    I have imported my video files from the DV camera. All done and I have the clips I want.
    I even edit then and place then in a timeline.
    I place effects markers etc. All in Premier Rro.
    But I don
    Emmanuel replied 19 years, 11 months ago 3 Members · 3 Replies
  • Harm Millaard
    October 12, 2006 at 1:21 pm
    Either export as movie from PP using MSDV AVI or use Adobe Media Encoder to export as MPEG DVD. In the latter case I suggest to export elementary streams, not program streams.
    The resulting files need to be imported into Encore as assets.
    Harm Millaard
  • Vince Becquiot
    October 12, 2006 at 11:14 pm
    If you are planning on setting menus with links to different areas in your footage, you can:
    1- Use chapter points in Encore and link throughout your footage.
    2- Create several sequences in Premiere and export separately as Harm mentioned.
    That will allow you to have fade in and outs, etc.
    One thing to consider: If you are worried about best possible quality, you have to keep in mind that exporting to DV may recompress your footage if you have effects applied to it and it will always recompress any images, animation. Heavy DV compression doesn’t pair up with DVD compression very well.
    If you have the room on your hardrive (200 Gigs+), you should export uncompressed, and then re-import in Encore and set the encoding to automatic.
    You can also make use of a bit rate calculator (Google up…) and export using the Adobe Media Encoder and choose Mpeg2 DVD. Again, here you will have to calculate the space requirement for your footage, but you will skip the uncompressed render.
    Vince
  • Emmanuel
    October 13, 2006 at 12:16 pm
    Thank you for your input.
    I have done two things to far.
    The first was to export as Mpeg2 (don
