Activity › Forums › RE:Vision Effects › Beginner-friendly tutorial for Twixtor Pro?
  • Beginner-friendly tutorial for Twixtor Pro?
    Posted by Juuso Voutilainen on October 30, 2009 at 8:50 am
    Hi, I have read the Twixtor and Twixtor Pro manual and searched the internet and Creative Cow forums quite a bit thoroughly without really finding a informative tutorial about creating and applying the foreground and background mattes, usage of tracking points and geometrical splines, all of the advanced motion guidance tools. So I would like to ask that if there exists, or if anyone could take some time and explain how to use this advanced features I would be very, very grateful. I am searching for best-possible slow-motion, and I am not getting satisfactory result with default settings, alot of disturbing artifacts appear. I have tried RealViz ReTimer PRO also, it has quite a bit good results, but it has some glooping (background distorting near foreground objects) and the output slow-motion video suffers from somekind of flickering (rapid luminance changes in video), so that is not good either. I am using Canon HV30 with 60i mode and a shutter speed of 2000. Thank you very much
    Greetings
    Juuso Voutilainen
    Pierre Jasmin replied 16 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Pierre Jasmin
    October 30, 2009 at 7:06 pm
    Not sure in what application you are tyring to run this in. For PRO features right now all we have is sample projects
    https://revisionfx.com/products/twixtor/help/#after_effects
    (at the end of that section)
    and some explanation in the html doc that comes with the installer
    Feel free to contact https://revisionfx.com/support/contact/
    It will autorespond with an ftp site login for you to send sample example for you to get additional help from support
    Pierre
  • Juuso Voutilainen
    November 2, 2009 at 12:59 pm
    Oh, I’m using After Effects CS4
  • Juuso Voutilainen
    November 18, 2009 at 6:49 pm
    Pierre, does Twixtor need foreground and background mattes for best slow-motion results? And if it is so, does it need frame-by-frame rotoscoping?
  • Eugene Lehnert
    March 17, 2010 at 3:29 am
    I am having a similar problem. I read the manual but I still get many artifacts. Did anyone post any advanced videos online somewhere?
  • Pierre Jasmin
    March 17, 2010 at 3:36 am
    You mean like this?
    https://library.creativecow.net/tutorials/revisionfx
    The ones at the bottom are for AE
  • Eugene Lehnert
    March 17, 2010 at 2:46 pm
    Thanks. I’ve seen these though. I’m looking for tutorials that feature the matte, tracking and spline options of Twixtor. My expectations might be high for the footage but I want to know the extent to which Twixtor can handle strange warping artifacts.
  • Pierre Jasmin
    March 17, 2010 at 5:49 pm
    We currently only have the sample projects here
    with the short explanation in the file:
    TwixtorAEExamplesReadme.htm
