Activity Forums Avid Media Composer Beginner Avid 6
  • Beginner Avid 6
    Posted by Lloyd Paul rivers on February 23, 2012 at 3:23 pm
    When i right click in the bin and select import footage a warning box appears saying. There are no media drives available. you will only be able to import shot logs. I have no idea what this means. I click ok and navigate to my folders where the 5d footage is located. Everything is greyed out, i just change the enable button from the shot log menu to any and it allows me to select my files. i click import and nothing happens. Also when the software first starts up it says “no media can be written to any mounted drive” please check with permissions
    any ideas what i have done wrong? i have only had the software a week
    Many Thanks
    Lloyd Rivers
    Shane Ross replied 14 years, 7 months ago 3 Members · 2 Replies
  • Hector Berrebi
    February 23, 2012 at 5:24 pm
    Avid has the option of drive filtering, usually on system or network drives, and usually selected by the user
    go to settings – media creation and check there
    i think i saw this issue on a mac running Lion with MC 5.5, is that your case?
    in any case, you should read a little on how to properly work with Avid.
    for DSLR, you shouldn’t import but rather link to AMA then transcode.
    also, you didn’t mention whether you had drives connected or not.
    Hector Berrebi
    prePost Consulting
  • Shane Ross
    Is this on a Mac or PC? Do you, in fact, have a drive connected that you intend to use as your MEDIA drive? If so, go into the MEDIA CREATION settings and set that as the destination drive.
    Shane
    Little Frog Post
