Activity Forums Adobe After Effects Expressions Before I Get Too Deep
  • Before I Get Too Deep
    Posted by Darby Edelen on May 9, 2007 at 4:49 pm
    Last night I started working on some expressions to reflect a camera across a 3D plane, which gets difficult when you want the reflecting plane to be able to occupy any position and any orientation and you want the camera to reflect its counterpart’s position and orientation.
    So I started with the basics that I thought I would need, and managed to get together an expression that gives me the distance between the camera and the 3D plane extended along its X-axis in space. I also have an expression that gives me the angle of incidence of the camera on the plane along the X-axis.
    So, before I get too far into this developing expressions for the angles of incidence along other axes and such, I thought I’d come on here and ask if anyone has done anything similar to this before and has some words of advice? Or any suggestions as to the easiest way (using the least information/fewest calculations) to calculate this accurately?
    Help? =)
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
    Dan Ebberts replied 19 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    May 9, 2007 at 5:34 pm
    Sounds interesting, but I’m having trouble picturing what you’re trying to do. What exactly do you mean by “reflect a camera across a 3D plane”?
    Dan
  • Dan Ebberts
    May 9, 2007 at 5:58 pm
    OK – I think i get it now. Couldn’t you just convert the camera’s position into the plane’s layer space, put the other camera at the same positon except for z, which would be the opposite value, and then do the same thing for the point of interest?
    Or do I really still not get it? 🙂
    Dan
  • Darby Edelen
    May 9, 2007 at 6:07 pm
    Well, the idea is essentially to create more realistic reflections in an AE comp, and the method I’m using stems from me remembering that a reflection can be considered a view from a camera that is the reflection of your viewpoint across a 3D plane. This picture should help clarify:
    https://img458.imageshack.us/my.php?image=reflectedcamerayn3.jpg
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Darby Edelen
    May 9, 2007 at 6:11 pm
    [Dan Ebberts] “Couldn’t you just convert the camera’s position into the plane’s layer space, put the other camera at the same positon except for z”
    That was the method I started out pursuing… I hate to admit it but I couldn’t figure out how to go from world space to layer space and back to world space =/
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Dan Ebberts
    May 9, 2007 at 6:16 pm
    Ah, OK – play around with this for the position of the reflected camera:
    c = thisComp.layer(“Camera 1”);
    p = thisComp.layer(“reflecting plane”);
    myPos = p.fromWorld(c.toWorld([0,0,0]));
    p.toWorld([myPos[0],myPos[1],-myPos[2]])
    Dan
  • Filip Vandueren
    May 9, 2007 at 10:13 pm
    I just finished a project with the ‘Apple’ reflection look.
    Since the ground- or mirror-plane was not moving, I duplicated my Comp, create a Null at the same position of the ground, parented Camera and a Null that was the point of interest to this ‘ground-null’ and the flipped the Null in Y: [100,-100,100]
    The angles are not really that important, it should always be a flip along a certain axis.
  • Andrew Kramer
    May 11, 2007 at 12:34 am
    I’m working on a project to simulate a mirror reflecting the opposite direction of a 3d “world” in AE. Pretty interesting study. I’ll post my findings…
  • Dan Ebberts
    May 11, 2007 at 3:23 am
    Looking forward to it!
    Dan
