Activity › Forums › Avid Media Composer › beep for covering swearing
Posted by Stephen Fenn on October 20, 2009 at 2:52 pmHello all, I just wondered how exactly you go about recording a beep sound to cover some swearing in an interview in Avid. Thanks.
Phil Lowe replied 16 years, 10 months ago 5 Members · 6 Replies -
Stephen Fenn
October 20, 2009 at 7:25 pmI did remember someone showing me a while ago. Something about using the audio tool to generate calibration tone and then using the capture tool to record it. Just can’t do it for some reason.
Michael Hancock
October 20, 2009 at 7:52 pmOpen your Audio Tool. Click the PH button and click “Create Tone Media”.
Set your tone level, frequency, length, number of tracks, target bin and drive.
Hit OK.
Avid will create tone according to what you enter and put in in your bin. Just load that into your source monitor and cut it into place.
Michael
I’ll be working late. -
Kenton Vannatten
October 20, 2009 at 9:48 pmI generally like to use a 750Hz tone as it’s more of a “booop” than an annoying “beep”. If you’re censoring the Osbournes, then the high-pitched variant can get annoying.
But, I agree with the other poster above that sometimes it’s better to just lift it out and leave silence.
Kenton VanNatten
Avid Editor (for hire) -
Phil Lowe
November 18, 2009 at 3:50 pm“If you’re censoring the Osbournes, then the high-pitched variant can get annoying.”
Hehe. More annoying than the Osbournes? 😉
