Activity Forums Adobe After Effects beck black tambourine video
  • Mark Woloschuk
    October 31, 2005 at 10:12 pm
    a friend of mine used a similar technique in an awards video. basically he exported his video as a series of still frames and then used a pict to ASCII text utility (you can probably find one on tucows) to convert the images. he then copied the resultant ASCII text into illustrator files so that he could zoom in and out of frames.
    easy, neh? bear in mind that this will work best with subjects shot or keyed against a white background and that to do it for 30fps over several minutes would be a mighty tedious endeavour. perhaps you can figure out some clever way to batch the process.
    mw
  • Satesh Ramjattan
    November 1, 2005 at 12:19 am
    maybe… create the text in AI or PShop, import and set the video as an alpha matte to the text.
  • Chris Smith
    November 1, 2005 at 1:27 am
    Steve found this link. Looks like some stuff in there that should work:
    https://dmoz.org/Arts/Visual_Arts/ASCII_Art/Software/
    Chris Smith
    https://www.sugarfilmproduction.com
