Beam effect and Coordinate Expressions for 3D Outlined Cube
I’m using the beam effect to make a 3D outlined cube and pick whipping the start and end point to the anchor points of nulls. I have 4 nulls to create the front and back faces of the boxes and then another set of 4 beam effect layers to make the sides of the box. I want to parent the 4 nulls to 1 null so I have more control over the position, scale, and rotation but when I do that it breaks the link to the beam effect and they no longer line up with the 4 nulls. I did figure out that if I pick whip the position of 1 of the 4 box face nulls to the position of the main null and add a +/- number to the end of the pick whip position expression i can move the null on the x-axis. All I need now is another piece of code to make it move on the y-axis but I can’t figure that out. Does anyone know an expression that can force position of a layer to a specific coordinate???
Beam effect layer expression
Start Point - thisComp.layer("Btm_L").transform.position
End Point - thisComp.layer("Btm_R").transform.positionBtm_L null pick whip expression
Position - thisComp.layer("Null 6").transform.position-100
