Activity › Forums › Apple Final Cut Pro Legacy › beach ball of death edit to tape or/and log and capt
  • beach ball of death edit to tape or/and log and capt
    Posted by Jeremy Hinkemeyer on September 16, 2010 at 2:11 pm
    I am running show leopard 10.6.4
    Mac pro 8 gbs memory and 2 x quad cores (intels)
    Aja kona 3 version 8 (have tried 7.1 and 7.5)
    Final cut version 6.06
    The problem I keep getting is related to edit to tape window and log and capture window. So I am thinking it has to do with aja kona card.
    When I open the edit to tape window it might freeze up with the beach ball of death. Or it might open the edit to tape window and I copy and past time code in the input or output and then the beach ball might pop up. (seems to happen randomly) I might have edit to tape open and then switch easy set ups, Then the beach ball might pop up. I even had the beach ball pop up when I switched the out going tone from -12 to -18.
    Log and capture window seems to be just a flakey. Might freeze on capture, Might freeze on marking input or out put.
    I have done everything from un-installing FC, changing all different kona versions. Deleting FC prefs and other files(tips of websites).
    Everything seemed to work good in tiger, But ever since I got snow leopard (clean install) I have had nothing but issues.
    I am sending a copy of this to apple, but guys at work think it’s a kona issue.
    Jeremy Hinkemeyer replied 16 years ago 2 Members · 3 Replies
  • Matt Larson
    September 16, 2010 at 5:36 pm
    Typically for me I’ll get the beach ball for 10 seconds or anytime I re-enable the L&C window or ETT, then it comes back normal. I’m guessing your doesn’t come back?
    Call AJA and ask to speak to tech support. They will help you.
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    AJA Kona 3 (6.0.1 drivers)
    G-Speed XL 12 RAID
  • Jeremy Hinkemeyer
    September 16, 2010 at 7:02 pm
    nope, Just beach balls forever.
    AJA asked me to try this VTR Exchange program, I will give it a shot, But I would think someone needs to figure out where this bug is, because Aja and FC should be able to work together.
  • Jeremy Hinkemeyer
    September 21, 2010 at 3:49 pm
    Bump.!!
    Does anyone else have any solutions?
    The VTR xchange is not going to work for me. The edit to tape feature is not productive enough for my means. I have media everywhere and its not all qt cut to time.
    Big projects, inserting small patches over other video, or capturing whole tapes,
