Activity › Forums › Apple Final Cut Pro Legacy › Beach Ball Blues
  • Beach Ball Blues
    Posted by Brian Berdan on November 30, 2009 at 11:05 pm
    Every 10 or 20 minutes or so I get a spinning beach ball interruption for about 10 seconds (seems like forever!). In searching for cause, here are the things I eliminated but which had no effect:
    Took project off of the same drive as media and put it on an external USB drive (slap my wrist for that one!)
    Turned off Time Machine.
    Made sure Spotlight wasn’t searching anything but internal drive.
    Had just one modest project open.
    Still happening….
    MacBook Pro 2.4GHz, 10.5.8, 4 gigs ram
    FCP 7.0.1
    ProRes-LT media on G-Raid 4TB via FW800
    Brian Berdan
    migrant filmworker
    Colin Mcquillan replied 16 years, 10 months ago 8 Members · 14 Replies
  • 14 Replies
  • Colin Mcquillan
    November 30, 2009 at 11:08 pm
    What is your autosave interval set to? do you have anything else plugged into the same FW Bus as the G-Raid(deck, I/O device…) how big is the project file??
    Colin McQuillan
    Vancouver, B.C.
  • Brian Berdan
    November 30, 2009 at 11:17 pm
    Hey Colin,
    Project size is 14MB
    Ah, yes, it must be just really slow auto-saving… I have that at 10 minutes (made it short after getting crashes early in my short FCP experience). Seems like it would save faster for such a small project… unless that’s not small by FCP standards.
    Brian Berdan
    migrant filmworker
  • Walter Biscardi
    November 30, 2009 at 11:22 pm
    If you have a lot of media on a slow media drive, it takes a while to autosave and it also makes FCP run slow over all.
    This is why so many of us run very high speed RAIDs with 4, 6, 8, 16 or more drives. Faster speeds mean better performance of FCP. There’s no way around that.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Brian Berdan
    November 30, 2009 at 11:30 pm
    Thanks Walter,
    Next week I’ll be running this off a desktop (3.2 8core Harpertown) and running the G-Raid via e-SATA… hope that helps.
    Brian Berdan
    migrant filmworker
  • Dean Sensui
    November 30, 2009 at 11:32 pm
    I turned off Autosave and developed a habit of constantly hitting “command-S” whenever I have done several steps.
    In the ancient past, “Autosave” used to cause more problems than not. And I learned to constantly save as I work. And then there are backups, too.
    Dean Sensui — Hawaii Goes Fishing
  • Raymond Tuquero
    November 30, 2009 at 11:33 pm
    G-Raid is nice … and eSata does help … but in the future I would recommend the Raid via Fibre Channel or using internal HardDrives. They are easy to install on the MacPros.
    -Raymond Tuquero-
    Houston Based Freelancer
    http://www.rtuqvidere.com
  • Brian Berdan
    Actually, now I see the beach ball is happening more often than auto-saving (I upped the time and checked the latest auto-save)… not sure what’s going on.
    Brian Berdan
    migrant filmworker
  • David Roth weiss
    November 30, 2009 at 11:41 pm
    [Brian Berdan] “not sure what’s going on. “
    1) Trash prefs
    2) Fix permissions using the Apple Disk Utility
    3) Run Disk Warrior
    If you’re still having the same issue after all of these you’ll most likely need a witch doctor or exorcist.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Colin Mcquillan
    November 30, 2009 at 11:42 pm
    [Raymond Tuquero] “in the future I would recommend the Raid via Fibre Channel or using internal HardDrives”
    A fiber RAID definitely, But why would you recommend an internal hardrive over an e-Sata RAID?
    A G-Speed eS RAID 5 or the like is far faster and more secure than an internal drive.
    Colin McQuillan
    Vancouver, B.C.
  • Rafael Amador
    December 1, 2009 at 2:41 pm
    [Brian Berdan] “Took project off of the same drive as media and put it on an external USB drive (slap my wrist for that one!)”
    What means that, that you have the media in an USB HD?
    You can not try to fix any performance issue having the media in an USB HD.
    You can not complain that your car runs slower having four flat wheels.
    Rafael
    http://www.nagavideo.com
