Activity › Forums › Boris FX › BCCAE6 Composition Question
  • BCCAE6 Composition Question
    Posted by Mark Santella on May 10, 2009 at 11:04 pm
    Thanks in advance for your help. I am trying to map bccae63d text to and 3depsextrusion (both in boris). The letters sit on top and in the middle of a heart. I have pickwhipped both the heart and the letters to a null to rotate them, but they don’t cooperate in tandem.
    I want the letters to stay in place (on top and in the middle of the heart) as I rotate the entire object or make camera moves. What am I doing wrong?
    …by the way…awesome awesome product
    thanks again for your help…I hope I was clear
    Peter Mcauley replied 17 years, 4 months ago 2 Members · 1 Reply
  • Peter Mcauley
    May 11, 2009 at 1:11 pm
    Well you’re going about it the right way, which is pickwhipping the 3D objects to a null and then using the null to control the 3D camera move.
    You need to make sure that you are pickwhipping the right camera property though – to create the effect that you want you need to set the built-in camera in both the 3D Text and 3D EPS to “Orbit” and link the tumble/spin/rotate camera parameters via the pickwhip to the null x/y/z rotation parameters.
    Cheers,
    Peter.
