BCC9: Extruded Text Window doesn’t load . . .
James Ollick replied 9 years, 6 months ago 6 Members · 16 Replies
James Simmons
June 17, 2015 at 8:13 pmBCC9 Type on Text didn’t work either. I am downloading Boris RED and Boris Graffiti now . . . .
James
James Simmons
June 18, 2015 at 1:21 am -
Sam Fuller
November 11, 2015 at 11:20 amI’m having the exact same problem as the OP. Vegas Pro 13, Windows 7 64, BCC 9, and the window doesn’t open. It doesn’t open in Type On Text either. This plugin is the main reason I wanted BCC in the first place.
This is a recent installation, so I can’t compare it.
I tried deleting the folders mentioned above. Didn’t help.
Has anyone figured this out?
Erik Davis
October 10, 2016 at 8:28 amI still have this exact same problem. Did anyone ever find a solution??? Thanks.
James Simmons
October 10, 2016 at 8:02 pmI found a solution: I switched to New Blue Titler Pro 4 and never looked back.
James Ollick
March 6, 2017 at 1:50 amJust an FYI. I am running Windows 10 Pro 64-bit OS, i7 950, 12 gig mem., Vegas Pro 14 Suite, several BCC Units. I just tried and the UI comes right up on BCC Type on Text.
James Ollick
