Activity › Forums › Boris FX › BCC9 / chroma key studio / 3d souirce alpha
  • BCC9 / chroma key studio / 3d souirce alpha
    Posted by Stewart Bourke on December 17, 2014 at 12:08 am
    Using BCC9 with VP 12, Chroma Key Studio added as a 2:1 composite because I want to use the light-wrap.
    My problem is that I need to move the chroma-keyed track in 3d space as well, but because I have BCC Chroma Studio with light-wrap on I do not appear to be able to do this.
    Is there a way to have have the 2:1 composite plus move the track around in 3d space?
    It seems I may have to render the chroma-keyed track and then import it into a new project and then do my 3d compositing? IS this the only way?
    Any help appreciated.
    STBO
    Russ Froze replied 11 years, 9 months ago 2 Members · 3 Replies
  • Russ Froze
    December 17, 2014 at 3:06 am
    HI, it is possible to make a track the child of a layer above. In this way several child layers can be affected by the parent track be it movement in 3d space or color adjustment to all the child layers and yes even go so far as to add light wrap to a group of children tracks.
    Russ Froze
  • Stewart Bourke
    December 17, 2014 at 9:21 pm
    Thank you – I was not aware of this facility.
  • Russ Froze
    December 18, 2014 at 6:35 am
    You are most welcome, this can be a bit confusing, Vegas does have an Easter egg or two.
    Russ Froze
