Activity Forums Boris FX BCC8 sony vegas pro 12 Problem
  • BCC8 sony vegas pro 12 Problem
    Posted by Matthew Funicello on October 23, 2012 at 1:13 am
    Hello Everyone Im having a issue for sony vegas pro 12 on installing
    Bcc8 for Sony veags pro 12 So I installed the BCC8 and put in serial number and everything but when I load up sony vegas pro 12 Its not in my effects. Now I open up sony vegas pro 11 And the bcc effects are in their. Also I have went on the Uninstallation process and it says repair I dont know why but when I try to repair it says
    Windows Installer
    The feature you are trying to use is on a network OK
    resource that is unavailable. CANCEL
    Click OK to try agian, or enter an alternate path to a folder
    containing the installlation package ‘BCC 8 OFX 32Bit.msi’
    in the box below
    Use source:
    C:UsersmattappDataLocaltemp_is3375 Browse…
    If I hit ok this pops up
    The path
    ‘C”UsersmattAppDataLocal]Temp_is3375BCC 8 OFX
    32Bit.msi’ cannot be found. Verify that you have acces to this location and try agian, or try to find the installation package ‘BCC 8 OFX32Bit.
    Please help me out on this problem I used BCC7 on sony vegas pro 11 and now that I have 12 I would like to continue using it,
    Thanks ,Sincerely Matt
    Matthew Funicello replied 13 years, 10 months ago 1 Member · 1 Reply
  • Matthew Funicello
    October 23, 2012 at 2:04 am
    Nvm I have had this problem fixed thanks any way
