Activity Forums Boris FX BCC7 Extrude Text in Vegas 10.0e
  • BCC7 Extrude Text in Vegas 10.0e
    Posted by Michael Gyori on July 15, 2011 at 2:23 am
    I have an EPS file that BCC7 won’t extrude properly…. For a few of the letters, it doesn’t draw the inner circle properly… it ignores the hole in one ‘e’ and another hole in a ‘d’. Is this a bug? Is there any way to attach a file in this forum?
    Peter Mcauley replied 15 years, 2 months ago 3 Members · 5 Replies
  • Peter Mcauley
    July 15, 2011 at 7:37 pm
    You might want to open the Illustrator file (In Adobe Illustrator) and make sure that all of the text has been converted to outlines. If this is the case then make sure that letters like o, d, e etc are using compound paths for the inner circle. And make sure that you save the file out in Illustrator 8 format – this is very important.
    I hope this helps.
    Cheers,
    Peter.
  • Michael Gyori
    July 16, 2011 at 12:23 am
    I made sure that all those letters have compound paths and no weird shapes. They look like any other letter than has been drawn correctly. I’ve saved both in Illustrator 8 and 10 formats… both seem to output the same.
  • Robert St-onge
    July 16, 2011 at 3:10 pm
    I have the same problem with the BCC Extruded Text in Vegas 10,
    using it with extrusion depth and bevel amount set to 0 and polygon count set to 80, just basic 2D Arial Black text, it ignores the hole in the e.
    At size 36, the problem occurs and having the font size set to 48 and the problem is solved.
    I need to use the master scale in order to make the text smaller and the letters displqy fine.
  • Michael Gyori
    July 17, 2011 at 7:42 am
    Thanks for the suggestion. I just scaled the whole EPS and the letters are now rendered correctly. Thanks.
  • Peter Mcauley
    July 18, 2011 at 12:53 pm
    Good news – very happy to hear that you were able to solve the issue by scaling the Illustrator original before importing into BCC. I hope this information helps anyone else that may run across this problem.
    Cheers,
    Peter.
