Activity Forums Boris FX BCC6 3d extruded text – critical error
  • BCC6 3d extruded text – critical error
    Posted by Daryl Brown on June 29, 2009 at 6:51 am
    i took screen shots of the error i get when i try to use 3d extruded text. I guess its because of my laptop graphics card. I don’t know anything about the drivers i have for it. Anyone know how to fix this?
    the error
    graphics card test results
    In heaven everything is fine
    Daryl Brown replied 17 years, 2 months ago 2 Members · 2 Replies
  • Boris Yamnitsky
    June 29, 2009 at 1:11 pm
    No, this may be an indication of some sort of installation mishap. Our installers place “shader” files on your system and it seems that the shader #19 for some reason can not be found by the plugin. It could be a registry problem or a problem of some files or directories moved around. Can you try to uninstall and re-install BCC? If that does not work contact our tech support
    888-77-BORIS
    Boris Yamnitsky
    BorisFX
  • Daryl Brown
    June 30, 2009 at 9:34 pm
    ok thanks, i guess ill re-install.
