Activity Forums Boris FX BCC5 crashing fcp 6.0.3
  • BCC5 crashing fcp 6.0.3
    Posted by John-peter Balas on May 29, 2008 at 12:59 pm
    First FCP kept crashing with BCC 5 installed
    so I removed it
    then it started crashing with Magic Bullet!!!
    Its killing me because at the start of my project everything was working smooth
    UNTIL
    I hit the 30min mark and BCC5 started crashing on timeline renders
    THEN
    I couldn’t export a quicktime ’cause that was crashing too
    “FCP quit unexpectedly, the may have been caused by a BCC5 *** plug-in”
    I even upgraded BCC to 5.0.5 to no avail-
    the project wouldn’t even open!!
    I read in another post here that the same thing was happening to someone with motion
    I’m using an ATI X1900 radeon card
    in a macpro 2007 intel 3Hz system
    with 7gb ram
    1.4tb video drive
    running leopard
    and FCSTUDIO 2
    Now Peter said he may have a fix for it HERE
    not sure what else to do-
    at this point I’ve uninstalled BCC5
    thanks
    J-P
    Peter Mcauley replied 18 years, 4 months ago 2 Members · 8 Replies
  • 8 Replies
  • Peter Mcauley
    May 29, 2008 at 5:36 pm
    Well the issue that I helped out with last December, to which you have provided a link in your message, was related to use of ATI Radeon video card – the problem disappeared when that user switched to a different “main” card in the system prefs. I don’t know if this will ever be fixed – it’s not something that we have any control over.
    Can you try an Nvidia Graphics card in the machine to see if this solves the problem?
    Peter.
  • John-peter Balas
    May 29, 2008 at 5:56 pm
    Peter, thanks for the reply-
    my windows computer has a NVIDIA 8800GT but I dont think I can use it in my MacPro- or can I?
    otherwise I’d have to go buy one…
  • Peter Mcauley
    May 29, 2008 at 6:35 pm
    Well it might work – see if you can find a driver for the mac for this card and if so then it might be okay. Ideally, you might want to see if you can get a halfway decent Nvidia card and if it works keep it but if it doesn’t solve the problem then return the card.
    Cheers,
    Peter.
  • John-peter Balas
    May 29, 2008 at 6:50 pm
    seems crazy that i have to get a new video card to fix this problem-
    Maybe its an openGL problem?
    I tried everything from
    trashing prefs,obj cache etc
    to repairing permissions
    etc etc
    nothing, and its crazy that the update won’t even let me open the project!!!
  • Peter Mcauley
    May 29, 2008 at 7:30 pm
    Hi John,
    I understand your frustration with this and if there was something that we could do to circumnavigate the issue then we would do exactly that but unfortunately I don’t think there is any other answer. At least for now this appears to be the case.
    By the way, have you attempted to open the project with the caps lock enabled before launch? This way, FCP is prevented from attempting to render to the screen before completing the launch process. Can you please give that a shot and let me know if this helps?
    Also, what BCC filter were you using when the host crashed? And can you tell me if the Magic Bullet software is FxPlug architecture and not using the AE API? You can see this in the effects window of FCP – if it’s FxPlug that will be listed as the filter class to the right of the name of the filter.
    Peter.
  • John-peter Balas
    May 29, 2008 at 8:06 pm
    caps lock ON
    open the project with BCC 5.0.1 installed
    project doesn’t open
    error message
    “The Application Final Cut Pro quit unexpectedly. The problem may have been caused by the BCC Effects plug-in”
    as for magic bullet – YES its an FxPlug.
  • Peter Mcauley
    May 29, 2008 at 8:14 pm
    Hi John,
    Well let’s see how we can help you resolve this issue and get the system back up. Please send me your direct phone line at peterm@borisfx.com and I’ll have our lead support specialist call you and go through this on the phone. Our first step is to get FCP back up and running. Then we’ll see about getting the filters working on that system. Please send me your number asap.
    Peter.
  • Peter Mcauley
    May 29, 2008 at 8:15 pm
    Hi John,
    Well let’s see how we can help you resolve this issue and get the system back up. Please send me your direct phone line at peterm@borisfx.com and I’ll have our lead support person call you and go through this on the phone. Our first step is to get FCP back up and running. Then we’ll see about getting the filters working on that system. Please send me your number asap.
    Peter.
