Activity Forums Boris FX BCC4.01 + FCP. Everything works except Transitions
  • BCC4.01 + FCP. Everything works except Transitions
    Posted by Sam Zimman on January 9, 2007 at 7:55 pm
    So I have the Boris Continuum Complete 4.01 installed and running fine on my PowerPC version of FCP 5.1.2, but none of the Boris Transitions work. If you try to apply one it corrupts the preferences (or maybe just the prof cache, have tested that) and crashes the application. Is this happening to anyone else?
    Also, has anyone got the motion tracker working in this setup? I’m having issues with it, but that could just be me not knowing how to use it correctly.
    Sam Zimman replied 19 years, 8 months ago 2 Members · 2 Replies
  • Paul Fx
    January 9, 2007 at 8:10 pm
    If you are using FCP v5.1.2, the BCC transitions will not work. Apple changed a few things between v5.1.1 and v5.1.2 that caused BCC’s transitions not to work. The filters work fine though. Apple (not Boris FX) is aware of the transitions issue and is currently working to correct it.
  • Sam Zimman
    January 9, 2007 at 9:12 pm
    that is exactly what i wanted to know. thank you.
