bcc3 compatible with RED 4?
Posted by Sergio Anaya on June 4, 2007 at 2:35 amAre BCC3 compatible to install with Boris Red 4? how?
Peter Mcauley replied 19 years, 2 months ago 2 Members · 2 Replies -
Peter Mcauley
June 5, 2007 at 3:25 pmWell actually you shouldn’t need to do that, as BCC 4 is included in RED 4, which means that you will already have the filters. Having said that, f you still want to install the BCC 3 filters into RED 4 that should work just fine.
Cheers,
Peter.
Peter Mcauley
June 6, 2007 at 4:04 pmAnd as an FYI, it should be noted that although the filters from the BCC 3 package are indeed included in RED 4, the included filters will only operate within the RED 4 user interface and cannot be used in any other host without RED. If you need raw filters with the host user interface then you will have to purchase BCC as a separate product or as a part of the bundle included in the Motion Graphics Pack.
Cheers,
Peter.
