Activity › Forums › Boris FX › BCC3 and avid alpha
  • BCC3 and avid alpha
    Posted by Bryan Parris on January 17, 2008 at 3:42 pm
    I confess I haven’t used these filters much over the years that they’ve been on the avid. I’m trying to add a transparency mode (like linear burn) to a graphic that already has an alpha (created in the title tool). I first looked at the Composite filter which has modes like this in it, but I can’t seem to get it to work with the alpha properly. For that matter, I can’t get any BCC filter to apply to the title properly. A pdf from Boris says it’s a one step process –
    “Any effect in the BCC AVX package can safely be added to a native Avid title and the alpha information is preserved along with the title making it a one step task to apply a directional blur or light zoom effect to the text.”
    However, when I drag directional blur to the title, all I see is the b&w alpha on the screen. If I hold alt and drag, it applies the effect to the video as if there’s no alpha.
    I’m using BCC version 3 with Avid MC Adrenaline 2.8. Is the BCC too old?
    Bryan
    Bryan Parris replied 18 years, 8 months ago 2 Members · 2 Replies
  • Peter Mcauley
    January 17, 2008 at 4:59 pm
    You need to enable the Apply to Title Matte function in the BCC filter in order for this to work.
    I hope this helps.
    Peter.
  • Bryan Parris
    January 17, 2008 at 5:13 pm
    Thanks Peter.
    Simple enough – so it’s a two step process :0)
    That does the trick.
