Activity Forums Boris FX BCC Units – Light Rays Win
  • BCC Units – Light Rays Win
    Posted by Bart Conover on August 16, 2011 at 9:44 pm
    Just purchased this unit and tried installing the 64 bit version for PPro CS5.5 . . . does not show up in the effects window in CS5.5 and does not show up as being installed in the media core set of effects.
    Windows 7
    Any advice? Thanks!
    Jeremy Ellis replied 15 years ago 2 Members · 1 Reply
  • Jeremy Ellis
    August 17, 2011 at 4:52 pm
    Hello Bart,
    When you run the installer try selecting Custom install rather than Complete. Doing so will take you to an option page for which host you want to install to, make sure the CS5.5 is selected. Once it’s selected it should show you the install path and allow you to change it if it is not correct. It should be as follows:
    C:Program Files>Adobe>Common>Plug-ins>CS5.5>MediaCore
    Thank You
    Jeremy
    Boris Support
