Activity Forums Boris FX BCC Swish Pan for Final Cut Pro
  • BCC Swish Pan for Final Cut Pro
    Posted by Kozo Okumura on December 27, 2010 at 4:16 am
    I just got the BCC 7 for Final Cut Pro and started playing with it.
    This may be silly question to ask but I just can’t figure out.
    I am trying to do simple swish pan by placing the BCC Swish Pan filter between the clip A and Clip B (Both Clip A and B have enough handles to overlap eatch other).
    And you see Clip A going out of the frame but you don’t see clip B coming in. In stead you see black coming in and then cut to Clp B. Am I doing something wrong or the filter file is somehow corrupted??
    Boris Yamnitsky replied 15 years, 9 months ago 2 Members · 5 Replies
  • Boris Yamnitsky
    December 27, 2010 at 4:39 pm
    Make sure that you are picking a BCC Swish Pan transition from Transitions category. Drag it over the cut. It should automatically pick up outgoing and incoming clips. The most recent version of BCC FxPlug is 7.02. To check the version get info on BCC FxPlug file in Library/Plugins/BorisFX
    Boris Yamnitsky
    BorisFX
  • Kozo Okumura
    December 28, 2010 at 1:39 am
    Yes, that’s exactly what I am doing and it is not working. When I checked the version, it says 7.0.1
    I went to the boris website to look for the upgrade but I didn’t see it. Should I re install BCC?
    thank you.
  • Boris Yamnitsky
    December 28, 2010 at 2:22 am
    Yes, you need to update to BCC 7.02 FxPlug. I believe it will solve your problem.
    Boris Yamnitsky
    BorisFX
  • Kozo Okumura
    December 28, 2010 at 2:53 am
    I looked everywhere in boris website but I couldn’t find the update to download.
    In update section, there are only updates for BBC 5 and 6.
  • Boris Yamnitsky
    December 28, 2010 at 12:06 pm
    Please try FxPlug 7.02 here
    https://www.borisfx.com/downloads/
    it’s the same installer as a trial version. It will respect the license already present on your machine.
    Boris Yamnitsky
    BorisFX
