Activity Forums Boris FX BCC snow/ rain in Graffiti, stick to layer
  • BCC snow/ rain in Graffiti, stick to layer
    Posted by Bart Molen on December 15, 2014 at 1:25 pm
    Using Boris plugin with NLE. BCC snow/rain adding to my text track.
    Interaction>Use”Stick to layer” Track, when it applies all particles remain at the top. Why is my particles staying at the top when using text within Boris?
    The only fix I have is apply the filter to NLE text track, however when I use customize, there is no text visible in Boris. Back in NLE the effect work fine. So, Boris is not recognizing the text from NLE.
    https://www.gripps.net/
    https://www.youtube.com/user/gripps2211?feature=mhee
    Bart Molen replied 11 years, 8 months ago 2 Members · 2 Replies
  • Jon Kozenko
    December 15, 2014 at 6:57 pm
    Bart,
    By default, the snow or rain will stick to edges based on Alpha – that’s why it appears on Graffiti-made titles, and the top of the clip. In the Interaction tab, however, right below the ‘Use “Stick to Layer” Track’ checkbox, should be a pulldown menu that is, by default, set to Alpha. If you change this to Luma, the rain or show should fall onto a bright title, or if it’s a colored title, you can change this to something like Red or Green.
    Hope this helps.
    Thanks.
  • Bart Molen
    December 15, 2014 at 11:11 pm
    Jon,
    Its always the little things. I was using black text, so alpha wasn’t seeing an object, even changing to luma /red or green. Once I changed the colour to white or any other, luma could see the object(text).
    Cheers and thanks.
