Activity Forums VEGAS Pro BCC render problems in Vegas 10
  • BCC render problems in Vegas 10
    Posted by Adam Spencer on March 26, 2011 at 12:56 pm
    I’m trying BCC 7 in Vegas 10, but it just seems buggy. I’m trying to use some of the auto-animated effects such as rain, comet, and clouds. Some of the presets for these effects will playback fine, other presets for the same effect do not animate at all – all that plays is a frozen frame (why??).
    I managed to get Rain working once and exported a rendered version before the thing died on me (phew). However, now whenever I try to use the plugin again, it does not auto-animate at all when rendering. It will playback fine if I set my preview window to Preview or Draft. But once I actually try to render it as MP4, all I get is a static frame for the length of the render.
    Thanks for any suggestions!
    John Rofrano replied 15 years, 6 months ago 3 Members · 3 Replies
  • Douglas Spotted eagle
    March 26, 2011 at 4:17 pm
    What is the source footage format?
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Adam Spencer
    March 26, 2011 at 10:47 pm
    I’m just using the effect on a solid black matte generated in Vegas, or on an empty event. My project is 1080p 25fps.
    I just tried changing the export preset to one of Vegas’ own MP4 presets without touching the export settings at all. Just to make sure my rendering preset wasn’t the problem. Unfortunately, that didn’t change anything. I still get a static frame for the length of the clip, even though it plays back animated in Vegas.
  • John Rofrano
    March 27, 2011 at 12:57 am
    What version of Vegas Pro 10 and what version of BCC7 are you using?
    You should be using Vegas Pro 10c and BCC 7.0.4. They are the most stable together.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
