Activity › Forums › Boris FX › BCC Optical Stabilizer
  • BCC Optical Stabilizer
    Posted by Clay Elder on September 5, 2010 at 5:56 am
    Recently moved to Media Composer 4.0.5 Win / Mojo. Trying to use BCC6 effects like Optical Stabilizer and if the clip is several seconds long, BCC causes the program to force close. I also tried BCC Extruded Text and work flow is very slow or doesn’t work.
    Are there settings that could be wrong?
    I edit on Xeon 3.4ghz with 2 gb ram , Quadro 1300FX card.
    Thanks for any help.
    Jeremy Ellis replied 16 years ago 3 Members · 2 Replies
  • Peter Mcauley
    September 7, 2010 at 1:49 pm
    We approved BCC AVX on a similar set up as the one that you describe and I don’t recall any issues with the Optical Stabilizer or the Extruded Text filters.
    Have you considered trying the latest version of BCC AVX (which you can download from https://www.borisfx.com) to see if this eliminates the problems that you are seeing with your system?
    Otherwise all I can suggest is that you please get in touch with one of our techs via email (support@borisfx.com) and they will assist you in troubleshooting the problem.
    Cheers,
    Peter.
  • Jeremy Ellis
    September 7, 2010 at 8:22 pm
    Hello Clay, please contact me directly at jeremye@borisfx.com if you are still having an issue so we may troubleshoot.
    Thank You
    Jeremy
    Boris Support
