Activity Forums Boris FX BCC Multithreaded in Vegas
  • BCC Multithreaded in Vegas
    Posted by Martin Rockwell on May 13, 2011 at 2:02 am
    Is BCC7 supposed to be multithreaded in Vegas? I get only a single cpu running and thus very slow rendering. Is there a setting somewhere I’m missing?
    John Rofrano replied 15 years, 4 months ago 2 Members · 5 Replies
  • John Rofrano
    May 15, 2011 at 3:28 am
    [Martin Rockwell] ” I get only a single cpu running and thus very slow rendering. Is there a setting somewhere I’m missing?”
    On my QuadCore I’ve gotten all 4 cores running at about 57%. This is with one empty event that contains an animated BCC7 Extruded Text object so all I have in my test project is one BCC7 event. This appears to say that BCC is multi-threaded. It also takes advantage of your graphics card’s GPU.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Martin Rockwell
    May 15, 2011 at 7:49 pm
    I don’t get it then. I have an i7 920 quad core and nvidia gts250. I get multicore performance on other things in vegas. My test is also 3d extruded text.
    what video card do you have?
    rocky
  • John Rofrano
    May 16, 2011 at 4:11 am
    [Martin Rockwell] “what video card do you have?”
    I have an nVidia Quadro 4000 but I don’t think the video card should matter.
    Do you only see activity on one CPU? or are all 4 running at 25% (which would also indicate single threading).
    Here is what my CPU’s are doing during a render:
    Here is the scene I am rendering:
    ~jr
  • Martin Rockwell
    May 16, 2011 at 3:31 pm
    I get maybe 20% total CPU usage, why I’m asking. Would you email me your project file so I can use the identical test? bastinado at e-z dot net.
    thanks,
    rocky
  • John Rofrano
    May 17, 2011 at 10:55 am
    [Martin Rockwell] “Would you email me your project file so I can use the identical test?”
    Sent.
    ~jr
