Activity › Forums › Boris FX › BCC Make Alpha help on Avid!
  • BCC Make Alpha help on Avid!
    Posted by Mike Dibenedetto on August 29, 2009 at 12:12 am
    I am trying to crop out part of one shot and put it over another. Normally I would use AniMatte in the Avid (Nitris DX), but I need to move the shot, and when I apply a resize under the animatte it effects the background as well. I read on a different forum that I could use BCC Make Alpha to crop the image and move it no problem. But I don’t see any way to draw a matte. I heard mention of finding a Custom Shape setting, but I can’t find it. What am I missing?
    Thanks so much for helping!!!
    Peter Mcauley replied 17 years, 1 month ago 2 Members · 1 Reply
  • Peter Mcauley
    August 30, 2009 at 2:40 pm
    To draw a spline mask using any BCC filter, you need to the following:
    • Set the PixelChooser to On
    • In the PixelChooser group, twirl down the Region group and select Custom
    • In the Effect Editor window, there is a vertically stacked array of buttons along the right side – click on the second one from the top, which is Custom Spline UI
    • In the Composer window, click and drag to create the shape that you want
    Hope this helps,
    Peter.
