Activity › Forums › Avid Media Composer › bcc glow tips?
  • bcc glow tips?
    Posted by Milton Hockman on May 24, 2007 at 11:14 pm
    i am trying to use bcc glow to make cool transitions.
    but it seems like mine doesn’t come out looking as cool as they do on tv shows.
    why is that?
    it seems like no matter what, my glow goes to an overall one color shade for a frame or two just before going to 0 percent.
    what are tips for making this effect look cool like on tv? any color choice tips? blur amounts? intesity amounts?? frame length tips?
    thanks.
    Grinner Hester replied 19 years, 4 months ago 3 Members · 5 Replies
  • Grinner Hester
    May 25, 2007 at 1:22 am
    I will post a complete tutorial on this very soon.
    Often, I start with a 5 drame dissolve. I’ll hop on the track above that and add an edit 5 frames before that dissolve starts and add another edit 5 frames after the dissolve. I will then throw a glow on there is filler. I ofen just use it’s diffualt settings on an added keyframe right in the middle, directly over the middle of that 5 frame dissolve benieth it. I then pull down brightness, width and crank up the threshhold on the first and last keyframes. Just 3 keyframes in total and the first and last are the same. You can (and should) vary this after a while so things don’t get repetitive. Aspect changes, ect. You can even “flicker” it a bit before the transitions with a longer length of filler effect and added keyframes.
    Imagination is key. It’s important to imitate looks to ensure capabilities and hone savvyness but it’s just as importent to then add a little something so they be copying you next time.
  • Oakmozart
    May 25, 2007 at 11:58 pm
    Cool idea, Grinner…I’ll have to try this.
    Thanks.
  • Milton Hockman
    May 26, 2007 at 3:41 pm
    thanks for helping me out grinner.
    i am not at my computer to try you effect but am in understanding correctly…the first and last keyframes are set to what?? i would imagine they would be set to 0 percent so the effect ramps up and then down. is that the case or no?
  • Milton Hockman
    May 26, 2007 at 5:58 pm
    grinner,
    not sure if you saw the movie, The Secret, but i think they use the exact trick. I stepped through it frame by frame and it seems to be the same.
  • Grinner Hester
    May 30, 2007 at 6:10 am
    yes. You can tell the editor on the last flick had it saved in a bin and the just reused it again and again in The Secret. Ya can’t really do this with saved effects. They are saved as a time savor…a good fast starting point on a new effect… not to be used as the same anne effect over and over.
