Activity Forums Boris FX “BCC Extruded Text” and “BCC Type On Text” “Launch Text Window” won’t open.
  • “BCC Extruded Text” and “BCC Type On Text” “Launch Text Window” won’t open.
    Posted by Soteres Joannou on September 14, 2016 at 8:41 am
    Boris Continuum Complete 9.0.2 for Sony Vegas 13
    I can’t get “BCC Extruded Text” and “BCC Type On Text” to work.
    When I click on “Launce Text Window” it won’t open the window.
    The “BCC Extruded Text” and the “BCC Type On Text” did not work from the time I installed Sony Vegas Pro 13 and Boris Continuum Complete 9.0.2.
    Vegas does not lock up, everything else seems to work fine. Just that the “Launce Text Window” won’t open.
    No new fonts were installed.
    Please help.
    Jon Kozenko replied 9 years, 11 months ago 2 Members · 1 Reply
  • Jon Kozenko
    September 17, 2016 at 12:14 am
    Hi Soteres,
    If you have not done so yet, I would recommend sending these three folders to the Recycle Bin, while Vegas is closed –
    The BCC OFX folder from here – C:\Users\[username]\AppData\Local\BorisFX
    The ‘13.0’ folder from here – C:\Users\[username]\AppData\Local\Sony\Vegas Pro\
    And the Workspaces folder(s) from here – C:\Program Files\Boris FX, Inc
    If none of these help, could you test to see if other prompts, such as the Licensing window or the FX Browser, are able to launch?
    Thank you.
    Jon
