Activity Forums Boris FX BCC extruded text AE Bug ???
  • BCC extruded text AE Bug ???
    Posted by Anhtu Vu on July 2, 2011 at 12:14 am
    Just d/l BCC extrude for AE CS5 for a test drive. Viewing does not work at different ratio, for example, with a 1920×1080 comp i can only view at 50%. Anything higher or lower will not work and once i enable anything but 50 %, the layer ( with BCC extrude ) goes blank. Once it happens, I have to exit AE and restart it again. Is this a bug ??
    I’m on CS5, ATI 5870, OX 10.6.4.
    Anhtu Vu replied 15 years, 2 months ago 2 Members · 2 Replies
  • Jeremy Ellis
    July 2, 2011 at 1:00 am
    Hello,
    Try setting it to full resolution (even if it your extruded text disappears) and save the project. Open the project back up and see if the text is back.
    Thank You
    Jeremy
    Boris Support
  • Anhtu Vu
    July 2, 2011 at 1:54 am
    Hi Jeremy,
    Even if you save your project at 100% view, it will reopen at 50% and as i’ve mentioned, 100% view does not work. I’ve spent 3 hrs with the demo so far, playing with BCC extruded text, and i find it VERY buggy. Mainly the layer just disappeared because of the problem mentioned above or intermittent layer disappearing simply by activating/playing a Camera layer. Basically anything to do with repositioning in 3D space just totally freaks BCC extrude out.
