Activity Forums Boris FX BCC Extruded Spline Issues
  • BCC Extruded Spline Issues
    Posted by David Didonato on December 13, 2010 at 6:10 pm
    I’m working in After Effects CS5 on a Mac running OSX 10.6.5. I have a shape I imported from Illustrator and extruded with the plugin. I finished my piece with everything working properly and looking good.
    When I tried to render the comp, I could see only a small rectangular portion of the shape in the render. After going back into the project, I cannot see the shape as long as the Extruded Spline plugin is applied and it doesn’t render properly.
    I created a new project to just test the plugin and nothing seems to work anymore. I thought I saw an OpenGL message at one point. Any help would be appreciated, Thanks.
    Jeremy Ellis replied 15 years, 8 months ago 2 Members · 1 Reply
  • Jeremy Ellis
    December 13, 2010 at 9:52 pm
    Hello David,
    Even if you are only seeing a small rectangle, try setting the resolution to full and then saving the project. Close out of After Effects and reopen the project. Let me know if the works.
    Thank You
    Jeremy
    Boris Support
