Activity › Forums › Boris FX › BCC Extruded EPS issue
  • BCC Extruded EPS issue
    Posted by Theo Brown on February 8, 2011 at 4:40 pm
    Hello, I’m having a problem setting up a hand-drawn Illustrator file in order to use it with BCC Extruded EPS. I screen captured the image in both Illustrator and After Effects (CS4 for both); there’s a hole in my image and some of the splines don’t look like they’re lining up. You can find it at https://www.flickr.com/photos/brown_theo/
    Any suggestions?
    thanks!
    people
    Peter Mcauley replied 15 years, 7 months ago 2 Members · 3 Replies
  • Peter Mcauley
    February 8, 2011 at 9:11 pm
    Hi Theo,
    The first thing that I would suggest is that you make sure that you have saved the file in Illustrator 8 format and that you are not using any special Pantone colors – only RGB and CMYK colors are supported.
    Also, if there is a bounding box surrounding the artwork then you might have to delete that as the filter will attempt to extrude any path that it can find.
    Compound paths should work.
    I hope this helps,
    Peter.
  • Theo Brown
    February 8, 2011 at 9:26 pm
    Hi Peter, the only thing I didn’t try (as you suggested) was to make the Illustrator file into compound paths — same result. I did save it as an Illustrator 8 file, there’s no bounding box and no crazy Pantone colors. Any other suggestions?
  • Peter Mcauley
    February 8, 2011 at 9:32 pm
    If you would like to send me the file I’ll take a look at it to see if I can figure out what the problem is. You can sent it to me via email at peterm@borisfx.com. Just make sure to zip the file before you send it.
    Cheers,
    Peter.
